Activity Forums Apple Final Cut Pro Legacy problems with exporting FC to quick time movie
  • problems with exporting FC to quick time movie
    Posted by Enrika Colusso on May 6, 2009 at 10:10 pm
    I’m trying to export my timeline (75min) to quick time and I keep getting ‘general error 49’ and often fc shuts down.
    I have filmed in dvcam Pal and until quite recently have been able to export to quicktime to make dvds of my rough cut.
    My sequnece settings are:
    size frame 720×576
    editing timebase 25fps
    pixel aspect ratio Pal – CC1R – 601
    Amanorphic
    Could you please let me know what could be the problem?
    thanks
    Joe Haughey replied 17 years, 4 months ago 5 Members · 6 Replies
  • Steve Eisen
    May 6, 2009 at 10:27 pm
    First make sure your timeline is completely rendered.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Joe Haughey
    May 6, 2009 at 11:33 pm
    try:
    re starting your system.
    delete render files and re render.
    trash prefs
    in that order
    Joe Haughey
    https://www.editmule.com
  • Enrika Colusso
    May 7, 2009 at 12:20 am
    Hi thanks for getting back
    A clarification. When you say delete reneder files do you mean go to the render folder and delete the files? How do you trush the pref.?
    sorry I am relatively knew to this as I am a director who is putting together a selected scenes trailer.
    Also it seems to be able to do it in bit, but not the whole timeline at the same time, though I have already done it with an even longer timeline…
    thanks for your help.
  • Rafael Amador
    May 7, 2009 at 2:28 am
    Hi Erika,
    Start by saving your project with a different name.
    Rafael
    http://www.nagavideo.com
  • David Hartnett
    May 7, 2009 at 3:09 pm
    One other thought – your 75 minute DV file will be over 16 Gb. An FAT-32 file system on a Windows machine will not handle files greater than 4 Gb. Or it could be some similar error.
    Editor – Speakeasy
    http://www.speak.co.uk
    FCPS & CS3
    6 Intel Macs w/Kona 3/LH
  • Joe Haughey
    May 7, 2009 at 3:29 pm
    go to the Tools menu / render manager, in there you’ll see where you’re render files are going, check and delete accordingly…
    trashing prefs:
    go to Library/Preferences/Final Cut Pro user data. in there, remove the three files with FCP icons, ie: prefs, obj cache and prof cache.. in the folder just prior to the user data folder delete the com.apple.FinalCutPro.plist file. restart your machine.
    all this basically serves to clean out your system of any weirdness that might be happening within FCP.. it usualy works too. the FAT32 issue outlined above could be a culprit too…
    hope it works…
    Joe Haughey
