Activity › Forums › Adobe Premiere Pro › problems with exporting
  • problems with exporting
    Posted by Eric Cook on July 28, 2009 at 6:35 am
    I am exporting at 1920 by 1080 at 29.976 fps with Photo-JPEG and square pixels to .mov. When I do this, the right hand of the video is broken up into horizontal sections that play at different speeds, or the right hand section is red and the video stays still… Any help would be much appreciated.
    Eric Cook replied 17 years, 2 months ago 2 Members · 4 Replies
  • Eric Jurgenson
    July 28, 2009 at 5:28 pm
    Does anything else other than .mov work? (like WMV?) If so, I would try running the clip through QT Pro after the conversion, and try changing the apeture to clean apeture in movie properties > presentation (This is a long shot).
  • Eric Cook
    July 28, 2009 at 6:17 pm
    Thanks for responding…I’m working on a mac, and the only video export settings I see are .mov
    also I’m using an HV 40 here are the import settings
    Type: MPEG Movie
    Image Size: 1440 x 1080
    Pixel Depth: 1440
    Frame Rate: 23.976
    Pixel Aspect Ratio: 1.333
  • Eric Jurgenson
    July 28, 2009 at 7:24 pm
    What is your original project setting? Are you shooting and editing in 24P?
  • Eric Cook
    July 28, 2009 at 9:15 pm
    yes
