Activity Forums Adobe After Effects Problems with encoding while fetching data
  • Problems with encoding while fetching data
    Posted by Mirza Kadic on March 25, 2024 at 11:09 pm
    Hi everyone, I’m fetching data from database with curl (system.callSystem), and data encoding is UTF-8. When I fetch data it returns wrong data. For example, correct should be: ‘Aïn Beïda’ but it returns ‘Aïn Beïda’. I tried fetching same exact command in terminal and the encoding is correct, seems like extendscript is doing something weird. Any ideas? Thanks!
    Hector Vera replied 2 years, 5 months ago 2 Members · 1 Reply
  • Hector Vera
    March 27, 2024 at 2:35 pm
    Here is an answer I found for your solution, hopefully this will help you. Check image attachment for the answer! 🙂
