Activity Forums Blackmagic Design Problems with DV in a new Decklink system
  • Problems with DV in a new Decklink system
    Posted by Manololp on March 13, 2007 at 10:59 pm
    Hello. I recently have purchased a Decklink Extreme to complement a DV editing system. The Decklink works fine (analog component uncompressed), but now I have problems with DV, in native editing and export to tape. Is possible export to tape a DV project (by firewire) with a decklink card installed?. I have not been success.
    Decklink Extreme PCI 5.7.3
    Asus P5B Deluxe
    Core 2 Duo E6600
    Nvidia 7600 GS
    2 Gb Ram
    1 TB raid 0 (200 Mb/seg write)
    Manololp replied 19 years, 6 months ago 2 Members · 2 Replies
  • This may be due to an improper pixel aspect ratio setting when you are setting up your project settings. DV 4×3 must be set to 0.9. If you have chosen a BM set up and modified it to 1.0 square pixe ratio, you will have this problem. Not saying that is your issue, but maybe. The default settings when you initialize BM project are correct.
  • Manololp
    March 20, 2007 at 1:47 am
    Hello Gene.
    Thanks for the answer, but this is not the issue.
    Please, see this link:
    https://forums.creativecow.net/readpost/124/865173?
