Activity Forums Apple Motion Problems with drop shadows and transparency
  • Problems with drop shadows and transparency
    Posted by Michael Del rossi on June 14, 2005 at 1:47 pm
    Hey all,
    I posted this at Apple discussions
    Does anyone else have the same problems?
    When I use drop shadows and fade in and out?
    The shadow comes through the fading element mostly evident in Light colored elements.
    AE does the drop right .
    Any suggestions?
    The files are here
    https://homepage.mac.com/mdelrossi/
    thanks
    mdr
    Michael Del rossi replied 21 years, 3 months ago 2 Members · 2 Replies
  • Mark Spencer
    June 15, 2005 at 4:13 am
    Go here:
    https://secure.vtc.com/cd/motion.htm
    and click on the two movies:
    -Problem with Changing Opacity
    -Solution for Changing Opacity
    Basically, you can keyframe the Levels filter instead of using the opacity parameter.
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, Final Cut Pro and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
    https://www.applemotion.net
  • Michael Del rossi
    June 15, 2005 at 10:33 am
    Mark,
    Thanks loads I don’t know if I would have ever come up with that answer.
    The closest I came to it was making the blend an add function and this realy only worked for white text not images.
    What were the knuckleheads at Apple Motion team smoking????
    =0
    mdr
