Activity Forums Adobe After Effects Problems with dragging and snapping a layer to a marker :-(
  • Walter Soyka
    October 9, 2014 at 1:14 pm
    [David Honan] “there’s tonnes of advice on how to get the playhead to snap but what about if you want to drag a layer to snap precisely to the playhead or marker.”
    Hold the Shift key while dragging the layer’s end point. This will allow you to snap in/out points, markers, and keyframes in the timeline.
    Also, the keyboard shortcut to set a layer’s end point is Alt+]. Since your marker is numbered, you could press 1 on the main keyboard to go to marker 1 (main numbers go to markers), then press 1 on the numeric keypad to select layer 1 if it is not already selected (numpad numbers select layers), then press Alt+] to set its end point to the CTI.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
