Activity Forums Apple Final Cut Pro Legacy problems with DPX-Sequence in FInal Cut
  • problems with DPX-Sequence in FInal Cut
    Posted by Larissa Goerner on May 19, 2008 at 11:38 am
    Hello there,
    i want to import dpx sequences into fcp 6.0.
    But it shows only grey or weird colored lines.
    The sequences are 4:2:2 YUV 10 Bit 720p/50 that have been encoded by a clipster. I have glue tools licensed and installed.
    Even quicktime doen’t show it.
    what can i do?
    thanks for help.
    Lara
    Gary Adcock replied 18 years, 4 months ago 2 Members · 5 Replies
  • Gary Adcock
    May 19, 2008 at 2:16 pm
    OK
    have you checked that the DPX files are playable? do they open in Photoshop?
    what happens with GT? ( and which version the new 3.0 version needs 6.02 to run correctly)
    it is odd that Clipster does 720 files – are you sure????
    Most of the off-camera devices do not record faster than 30p
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Larissa Goerner
    May 19, 2008 at 2:43 pm
    hi,
    i have a GT 2.5.11. We converted 1080i to 720p/50 with an Alchimist and then built the DPX files in the Clipster. I did the update to 6.02 in Final cut but there is no change.
    any ideas?
    Settings are:
    GT:DPX-InputConversion: Auto Detect
    Aspect Ratio: None
    Alpha Ignore
    DPX-Output: 10-bit Standard LOG-LIN
    Frame digit Pad: 4;
    No changes else,
    FC:
    Sequence: HDTV 720p
    Pixel: Square (i hope i translate it the right way, as german version)
    Quicktime video: 10-bit Uncompressed 422
    i have it in the bin and did double-click -> nothing happend
    i put it in the timeline and rendered.
    results are the same.
  • Gary Adcock
    May 19, 2008 at 2:52 pm
    [Larissa Goerner] “i have a GT 2.5.11. We converted 1080i to 720p/50 with an Alchimist and then built the DPX files in the Clipster. “
    My guess is something is wrong with the DPX files- I have never seen a clipster do 1280 x 720 frames.
    what do the files look like in Photoshop?
    gary adcock
    Studio37
  • Larissa Goerner
    May 20, 2008 at 7:15 am
    files can be read in graphic converter and look ok.
    i’ll check out files when clipster comes back from repair.
    thank u for your help.
    Larissa
  • Gary Adcock
    May 20, 2008 at 1:45 pm
    [Larissa Goerner] “files can be read in graphic converter and look ok.
    I was very specific
    I asked how they looked in PHOTOSHOP- graphic converter allows for non standardized DPX and Targa files- Photoshop will not open anything but a legal DPX file.
    gary adcock
    Studio37
