Activity Forums Video Copilot Problems with Disintegration tutorial
  • Problems with Disintegration tutorial
    Posted by Paul Ekert on June 25, 2009 at 8:30 am
    I’ve been having a workflow and render problem with After Effects 7 and the Disintegration tutorial on Andrew Kramers rather excellent web page.
    https://www.videocopilot.net/tutorials/disintegration/
    I get this error about half way through the tutorial.
    Error 25::237 curves returned and invalid Max_result from PF_Cmd_Smart_Pre_render
    For me this error displays after I add the SAM footage to the timeline and then try to create a second distegrate comp to add the other effects. Sadly it means I cannot finish the second half of this excellent tutorial.
    I also get this error if I attempt to render out although a Pre-Render will work?!?!?
    Just not going to work in AE7 or a problem with my setup?
    Intel 6600 Quad – GT9600 512mb – 4gig ram.
    Paul Ekert replied 17 years, 3 months ago 1 Member · 1 Reply
  • Paul Ekert
    June 25, 2009 at 10:05 am
    Update to the above.
    I meant the Save Ram Preview works, the Pre-render gives an error message as well.
