Activity › Forums › Apple Final Cut Pro Legacy › Problems with Directory structure in P2 cards
Alek Kubak replied 14 years, 7 months ago 4 Members · 12 Replies
Craig Dulas
February 2, 2011 at 5:51 pmHERE IS THE ANSWER!
Thanks for all the help and we learned a tiny trick that works with the P2 Directory Structure error (for anyone else who made this mistake);
If, you change the name of the CONTENTS folder on the p2 card data, sometimes you can just change the name back to CONTENTS. However, this does not always work. You need to open a new folder, name it CONTENTS, then move the other 6 folders into it. That worked for us on all files affected.
Thanks again!
Cheers
Craig -
Alek Kubak
February 8, 2012 at 7:11 pmThanks guys (Shane and other users of the blog), I got some footage to edit just the material on my HD I did not see the tapes or anything, first folder worked out just fine, but the next ones did not, the problem, someone at the camera rental place renamed the files, as conntents2, contents3 and so forth, after reading your posts all I had to do, is to rename each folder back to contents and that fixed it!
