Activity › Forums › VEGAS Pro › Problems with cookie cutter effect. Please help
  • Problems with cookie cutter effect. Please help
    Posted by Jessica Devlin on November 8, 2008 at 5:30 pm
    Ok. I’m new and I ha ve Sony Vegas Pro. I used a tutorial and mastered how to use the cookie cutter effect. I learned how to make a split screen with it while using the picture in picture type. Last week I had some problems with the program and messed with some settings. Now when I make a split screen, the speed of both videos is much slower, almost stop motion animation. When I take out the effect, the video runs smoothly. Only the slip where the effect is used runs slow, the rest of the video runs fine.
    I think I messed with a setting and that’s why it’s not working right now. Is there anyone that can help?
    Ashloey Angel replied 17 years, 10 months ago 3 Members · 4 Replies
  • Mike Kujbida
    November 8, 2008 at 9:45 pm
    Since things are OK without the FX, I can offer two guesses.
    Number one is that your Preview window is set to Best/Full.
    If that’s the case, drop it down to Preview/Auto and see if that helps.
    The image quality will take a hit but, as this is for preview purposes only, it’s OK as the final render will still look good.
    To get a smooth preview of the FX section, highlight it and do a RAM render (Shift+B).
    The other thing it could be is that your computer is underpowered and just can’t keep up to what you’re expecting it to do.
  • Jessica Devlin
    November 8, 2008 at 11:23 pm
    This didn’t help. Is there any way to default all settings? My fx is very slow still
  • Mike Kujbida
    November 9, 2008 at 3:08 am
    To reset Vegas to its default settings, hold down Ctrl and Shift while starting it up.
  • Ashloey Angel
    November 21, 2008 at 11:01 pm
    i have a question dealing with the cookie cutter. im trying the effects but it wont show up on my window/screen. i dont know how to fix this, i been trying to but i cant. do you know how to?
