Activity › Forums › Maxon Cinema 4D › Problems with Constraints in Cinema 4D R13
Posted by Janek Prähofer on January 16, 2012 at 7:26 pmHi,
I’m confused about Constraints. Is there any Way to get Object A moved and Objects B, C & D follows Object A as shown in the Image below? I’m using Cinema 4D R13. I’ve tried Constraints, Joints etc. but nothing seems to work out! I apreciate your help!
Thx in Advance
Cactus Dan replied 14 years, 8 months ago 4 Members · 5 Replies -
Adam Trachtenberg
January 16, 2012 at 10:02 pmProbably requires some better math/scripting skills than I possess to make something more controllable, but here’s a dynamic rig:
3543_hingrig.c4d.zip -
Janek Prähofer
January 17, 2012 at 11:53 amHi Adam,
thank you for your fast Reply!
Basically your Solution is right but i don’t want Object A to be moved by the Cube. I want to move Object A itself and the other Objects should follow. Is it pure Math or is there some Way to solve it with Xpresso, Ik or Constraints?Here’s a little Example i found: https://en.etudes.ru/utils/dl.php?file=/en/mov/mov028/EtudesRu_kempe.avi&name=%DD%F2%FE%E4%FB%20:%20%D2%F0%E8%F1%E5%EA%F6%E8%FF%20%F3%E3%EB%E0&size=Large&rand=9745209
Janek Prähofer
January 17, 2012 at 3:34 pmHi Adam and thank you for your quick Reply. Your Solution is quit right but i ment to move Object A ( a not Object A moved by the Cube) and the other Objects follow it as in the Example below.
https://reels.creativecow.net/film/hinge
Randy Johnson
January 18, 2012 at 8:20 amI just did this:
https://skitch.com/randy-johnson/g3sbi/engcon-v4.c4dI needed to separate my hierarchy for a lot of reasons but I ended up using target tags and pointing one corner that way.
/Randy
Cactus Dan
January 19, 2012 at 2:15 pmHowdy,
Most folks try to over analyze these kind of setups, when they’re usually quite simple to set up with IK.
https://www.cactus3d.com/HingeMechanism.movAdios,
Cactus DanCinema 4D R10 XL Bundle, BodyPaint, Dynamics
http://www.cactus3d.com
http://www.cactus3d.com/Plugins.html
