Activity › Forums › Apple Final Cut Pro Legacy › problems with chroma key, better in Premiere!
Posted by Merete on April 19, 2005 at 8:36 amI
Kevin Monahan replied 21 years, 5 months ago 5 Members · 5 Replies -
Tom Matthies
April 19, 2005 at 1:55 pmI’ve never been too impressed with the chroma keyer filter in FCP. I just never seem to get that “nice” key from it. I’ve been using DVMatte for about a year with good success. It’s not too expensive and easy to use. Might want to try it. They used to have a free, downloadable version to try it out.
Otherwise, for your problem, you might try adding the matte choker filter after the CK filter and try to “squeeze” your keyed material down a little. It might help get rid of the green fringe a bit. Add the spill suppressor filter as well. Try adding the spill filter before the choker and see if that helps. Play with the various controls until you get a combination that works best for your particular situation.
Tom -
Max Frank
April 19, 2005 at 3:56 pmPersonally, I’ve been able to execute excellent Keys in FCP on DV, so I don’t know what all the fuss is about.
But anyway, I also found that using the keyer in Boris BCC can also be a great tool.
Wayne
2DP G5, 3.5GB RAM, FCP HD
Walter Biscardi
April 19, 2005 at 7:51 pm[Wayne K.] “But anyway, I also found that using the keyer in Boris BCC can also be a great tool. “
That’s a MUCH better keyer than Apple’s own Chroma Keyer. In fact I tell everyone that BCC should be on every editor’s workstation as it’s a nice “swiss army knife” of filters, effects and tools.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Kevin Monahan
April 19, 2005 at 9:28 pmI have a step by step article I wrote for Ken Stone.
https://www.kenstone.net/fcp_homepage/chroma_key_fcp_hd_monahan.html
This process is also covered in my book in detail and has exercises to boot.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com
