Activity Forums Adobe After Effects Problems with CC Particle World preset
  • Problems with CC Particle World preset
    Posted by Konstantin Smirnov on May 3, 2020 at 1:06 pm
    Hi
    I have two questions concerning the CC Particle World preset.
    Question one:
    I have problem positioning the palm trees (see pic) on the same Y-axis. They seam to be scattered on different levels. The producers coordinates are all set to zero. The texture on the particles are all the same. The scatter is set to zero. Every option under physics are also set to zero. How could it be that the palm trees are not aligned on the in the Y-axis? And what could I do to achieve that?
    Question two:
    I cannot draw in the Opacity Map. When I click or drag nothing happens. How come? Does anybody have a clue on what I’m doing wrong?
    I run the version 17.0.6 of After Effects 2020.
    Konstantin Smirnov replied 6 years, 4 months ago 2 Members · 2 Replies
  • Richard Garabedain
    May 4, 2020 at 2:32 pm
    in order to use the opacity map you must be using the arrow tool. and the y radius is not quite zero..also the z space can make them look like they are uneven…switch to the front view to test
  • Konstantin Smirnov
    May 5, 2020 at 9:46 am
    Thanks. Works like a charm!
    _____________________________
    KONSTANTIN SMIRNOV
    Video editor // VFX // Graphic designer
    FROGTOWN
    Web: http://www.frogtown.se
