Activity › Forums › Apple Final Cut Pro Legacy › Problems with capturing media w/ Mini DV deck via firewire
Posted by Crys on May 1, 2006 at 1:45 pmHello, I’m using a Panasonic DV2000 Mini DV deck and trying to capture some footage via firewire. FCP recognizes the machine (I can control it), but there is no picture (just bars). I’ve tried changing the settings around, but I still cannot see the video. Right now I have it set on:
DEVICE CONTROL – FireWire NTSC Basic
CAPTURE/INPUT – DV NTSC 48 kHzFCP HD 4.5
MAC OS X Version 10.4.6
Dual 2.5 GHz PowerPC G5
3.5 GB DDR SDRAMThanks in advance for any help!!
Crys replied 20 years, 4 months ago 5 Members · 6 Replies -
Luke David
May 1, 2006 at 2:45 pmUse the CCow search engine to find more postings on this topic. I had the exact same issue and resolved it by trashing the quitime receipts and deleting and re-installing QT player. I am willing to bet that is the issue, but do the search for better instructions.
Shane Ross
May 1, 2006 at 2:49 pmIf you updated to QT 7 recently?
Shane’s Stock Answer #30:
https://discussions.apple.com/thread.jspa?messageID=1063600􃪰
The credit for this goes to Bob Sidebotham:
I was just walked through a repair procedure by an Apple Care person, and it fixed my camera recognition problems (I have a Canon XL1 and sometime after installing Tiger, then 10.4.1, various patches (including Quicktime 7.1) and the latest Desktop Video patch, I’ve been unable to use the camera with Final Cut Express, and attempts to capture would result in a FCE crash).
The workaround is to download Quicktime *manually*, after removing the “receipts” which indicate that it is loaded. Specifically, I was told to do the following:
1. Navigate to Library -> Receipts on your main drive (not from your personal folder).
2. Remove all files of the form QuickTime*.pkg, where “*” is a version number. E.g. QuickTime600.pkg, QuickTime650.pkg, Quicktime700.pkg and QuickTime701.pkg. This simply tells your system that those packages are not installed.
3. Go to https://www.apple.com/quicktime/downloads and click on the “download Quicktime” link. DO NOT USE THE AUTOMATIC UPDATE UTILITY. Download QuickTimeInstallerX.dmg. Double click this file (probably on your desktop) and then invoke the installer by double clicking QuickTime701.pkg.
4. After your computer reboots, you should be able to restart FCP and see your camera.
Shane
Alokut Productions
http://www.lfhd.net -
Siencynl
May 1, 2006 at 3:11 pmI’m pretty sure that 4.5 won’t work with qt7. I was told not to uprgrade qt until I’d upgraded fcp to version 5. Cnsequently you need to search the apple downloads archive for qt version 6
Crys
May 1, 2006 at 5:14 pmYes, I always try to search the forum before posting a question, but I guess I did not do a very good job with the searching this time…
I’m pretty sure I have done those instructions to upgrade to QT7. I was told to upgrade before to fix some other problem; not the current problem I am having now.
If I go back to QT6, it may fix this problem I have now, but my other problem that I had before (wish I could remember what it was!!) will probably come back. Is it best to upgrade to FCP 5?
Jim Martin
May 1, 2006 at 7:01 pmFCP 4.5 should work with QT 7.01 and recognize the deck, but not with QT 7.04.
jim
Crys
May 1, 2006 at 9:46 pmI’ve encountered another problem…
I followed the instructions and deleted all QT files and download QT 7.01. When I try to install 7.01, Quicktime will not let me install on the Macintosh HD. It says that “the disk is dimmed because it does not contain an appropriate version of QuickTime”
Did I do something wrong?
Thanks again for your help!
