Activity Forums Adobe Encore DVD Problems with buttons
  • Problems with buttons
    Posted by Mariano Cerdá cabrera on September 29, 2014 at 2:54 am
    Hi, sorry if this was already posted, but I couldn’t find any solution for this.
    So I’m working on this DVD for the first time and I’m using Encore, I have it from Master Collecion CS6 and I have the following problem:
    It’s a concert DVD and the main menu has a button that leads to the song list of the bands. The problem is that every button is working Except some from 1 of the bands, it’s really weird, They are all made the same way, but it seems those from one of the bands won’t work, they aren’t selectable.
    Tim Sutton replied 11 years, 9 months ago 3 Members · 2 Replies
  • Stan Jones
    September 29, 2014 at 4:27 am
    This is usually due to exceeding the button max:
    For a DVD 4:3 menu, you can have no more than 36 buttons. For a 16:9 menu, 18 buttons.
    Stan Jones
  • Tim Sutton
    November 17, 2014 at 11:59 pm
    If you have automatic button routing turned on, it might be that your buttons aren’t routed correctly.
    Click the button on the bottom of your preview window that’s circled here: https://i.imgur.com/M5xXLBh.png
    Those images on top of the buttons show the button mapping directions, all you need to do is click-and-drag from one button to another as needed. Hope this helps!
    View post on imgur.com
