Activity Forums Apple Final Cut Pro Legacy problems with audiotrack in mpeg1 codec
  • problems with audiotrack in mpeg1 codec
    Posted by Seben on May 31, 2005 at 9:30 am
    hello,
    i have a strange problem with final cut pro and compressor.
    when i export/convert my fcp sequenz to the mpeg-1 codec with compressor, the audio track
    looses it’s synchronisation to the video track. in the first minutes there is no
    visible/hearable offset, but after 3 or 4 minutes the video seems to be faster than the
    audiotrack.
    there is no problem with the synchronisation, when i export the sequenz directly
    via “export as quicktime” with the mpeg4 codec.
    but i need mpeg-1!!!
    any ideas???
    thank you
    seb.
    Seben replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 31, 2005 at 12:39 pm
    How did you send the sequence to Compressor?
    Jerry
  • Seben
    May 31, 2005 at 1:09 pm
    “How did you send the sequence to Compressor?”
    directly with the export function from final cut pro.
    in the meantime, i’ve tested other ways to convert my video
    and i’ve found the same sync problem when i convert a mpeg4 video
    to wmv9 (using the wmv-9 plug-in for quicktime pro).
    strange…..
