Activity Forums Apple Final Cut Pro Legacy Problems with animation codec
  • Problems with animation codec
    Posted by Benny G on April 11, 2007 at 6:43 pm
    I already posted this question in the compression techniques forum, but havent gotten a response yet, so im reposting in this forum as it is related so….
    Hello, I am doing a batch export from FCP of about 76 sequences using the QT custom option (animation codec, best quality, million+ colors, 720*480). The problem Im having is that any sequence over 2.5 minutes in length, I get an error message saying the file is to big. There is 1 sequence, (the first one), that was 3 minutes and still worked, but this is the only exception to the whole export. All the rest fall into the 2.5 min conundrum: under 2.5 min. succesful; over 2.5 min, error, file too big. Any thoughts would be greatly appreciated, this animation codec is new to me, but I need to figure out this problem immediately.
    benny
    Benny G replied 19 years, 5 months ago 3 Members · 5 Replies
  • Rafael Amador
    April 11, 2007 at 6:56 pm
    Why do you need Animation? Are you exporting Alpha?
    Rafael
  • Benny G
    April 11, 2007 at 7:02 pm
    Im using animation because I have to compress further with divx, and want to maintain the highest quality. Also, its in the specs I have for this project.
  • Rafael Amador
    April 11, 2007 at 7:19 pm
    Animation codec is RGB so I don’t think is the best if you go to end up in divex that, if I;m not wrong, is MP4, so YCrCb based.
    Animation make very big files. You can get the same quality with much smallers files. With PhotoJPEG 100%, 8b Unc for example.
    Also if you are not exporting Alpha chanell, export in Millions of Colors. Never Millions+ . This doen’t give more quality but add an alpha Channel. 32 bits instead of 24. Bigger files for nothing.
    Cheers,
    rafael
  • Russell Lasson
    April 11, 2007 at 7:22 pm
    I’d just export it from whatever you edited as. You’re going to crunch it anyway.
    -Russ
  • Benny G
    April 11, 2007 at 7:53 pm
    Thank you both for the information about the codec, the million+ thing is really good to know. I would rather export to divx straight from final cut, but when I try to batch export using divx, I cant change the divx settings, default only. Is there a way around this?d So that would mean Id have to do 76 sequences manually, and I was hoping to set this up at the end of the day and leave, so Im not tying up fcp all day. Any ideas as to the 2.5 min problem I was having? Ill try changing million+ to milion and see what happens.
    thank you for your time, I really appreciate the insight.
    benny
