Activity Forums Adobe After Effects Problems with After Effects Audio while rendering
  • Problems with After Effects Audio while rendering
    Posted by General Confusion on December 30, 2005 at 4:19 am
    I am using After Effects to condense a short film originally rendered in Premiere Pro, but continuously receive the same error message. The original film has an audio track with the following specs 32.000 kHz/16/bit/stereo. I have matched the identical settings in the AE render queue, and have also lowered the quality, but I always get this same message: After Effects error: opening sound component (-2166).(10::44) Any insight would be greatly appreciated.
    Efe Ozler replied 20 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • David Braswell
    December 30, 2005 at 8:16 pm
    Can you preview the audio in After Effects? What format is the movie and audio?
  • General Confusion
    December 31, 2005 at 12:28 am
    Thanks Mav-
    The movie is a quicktime film and the audio was a wav. file. I can RAM preview it, but I can’t render it completely without the error message coming up.
  • David Braswell
    January 2, 2006 at 4:41 pm
    That’s strange. I would try searching the forums at Adobe. Also, you may want to try separating the audio from the video and importing it into AE by itself.
  • Sherik
    January 7, 2006 at 5:19 pm
    If you find the solution to this problem I would love to know. I get the same error. I have a individual .wav file that plays fine seperately. When I try to render in AE it gives me that exact error message. Ugh! Every now and then it will do a ram preview with it, but it definately will not render as a movie.
  • Reldor
    January 11, 2006 at 10:28 pm
    Downgrade your quicktime. I did it and it worked for me
  • General Confusion
    January 11, 2006 at 11:15 pm
    Thanks Reldor.
    Worked like a charm.
  • Efe Ozler
    April 14, 2006 at 6:26 am
    i hope it s not so late to ask a question to this post, but i really wondered which version of quicktime did you have and which did you downgrade to ?
    EFE
