Activity Forums Adobe After Effects Problems with AE after Leopard 10.5 update
  • Problems with AE after Leopard 10.5 update
    Posted by Chance Norris on December 3, 2008 at 5:52 pm
    Has anyone experienced any problems with AE CS4 after updating to Leopard 10.5.
    I have been experiencing Image Buffer Errors on export and during previews with version 7.0.
    Just downloaded trial version of CS4 and now can’t preview in realtime on playback. Preview plays at 5 fps.
    I’m also running bootcamp with Vista 64bit on same machine and AE CS4
    works fine.
    Mac Pro 8 core version (2,1) 8 gigs memory, 7300 GT, Kona LHE
    Any Ideas?
    Chance Norris replied 17 years, 9 months ago 2 Members · 2 Replies
  • Kevin Camp
    December 3, 2008 at 7:16 pm
    [chance norris] “I have been experiencing Image Buffer Errors on export and during previews with version 7.0.”
    ae7 is only powerpc based, so if you have an intel-mac (macpro, mackbook, later imac, etc), ae7 has to run under rosetta (powerpc emulation). i would guess that apple is less concerned with rosetta working well with later os versions and updates, it was just a stop-gap for a period of time until intel-native versions of software was available for intel-macs. so that may be your problem with ae7.
    there was also a long set of things to do to get ae7 to run well on intel-macs… reduce the max memory usage drastically (like from 120% to 60% or 30%) and the ram cache from 60% to 30% or 15% respectively), disable opengl and avoid using the bundled cc effects… even after those i still saw frequent image buffer errors that were not fixed until the intel-native cs3.
    [chance norris] “Just downloaded trial version of CS4 and now can’t preview in realtime on playback. Preview plays at 5 fps.”
    if you are hitting zero on the numbers pad for ram previews, then the only thing i can think of for slow ram preview playback is that you are playing back through a video output card (decklink, aja, etc) and there are some setting that need to be tweaked to get realtime playback (or just set video preview to montior only).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Chance Norris
    December 4, 2008 at 4:20 pm
    Thanks for the help it was the AJA Preview.
    System Details
    Mac Pro (2,1) 8 Core , 8 gigs memory, (Nividia 8800GT on the way) replacing current 7300 GT , Leopard 10.5 / Vista Business 64bit Bootacamp, AJA Kona LHE
    FCP Studio, Adobe Premium Production CS4, Eyeon Fusion, Softimage 7.0 , Lightwave 9.3
    Chance Norris
    Dvfootagesource
    Houston Texas
    409.771.9355
