Activity Forums Apple Final Cut Pro Legacy Problems with 10.4.6????
  • Problems with 10.4.6????
    Posted by Stevec on June 6, 2006 at 12:39 pm
    Hi there. I’m just taking a survey basically.
    We have been having problems with 3 G-Raid drives intermittently going offline and progressively getting worse until the drive will not mount.
    My Mac expert is telling the powers that be that this is due to problems from the OS 10.4.6 update that we downloaded and installed from Apple.
    He says that there are major problems with 10.4.6 and he has had to completely rebuild a dozen systems.
    We have had no problems with the systems other then this issue with the G-Raids.
    My question is….
    Has anyone else had issues with 10.4.6 in anyway?
    Steve Cohen
    Editor
    O2 Production Studios
    Stevec replied 20 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • David Bogie
    June 6, 2006 at 2:32 pm
    We have had no issues with 10.4.6 but our setups are different than yours or probably any of his.
    I have found these blanket warnings to be silly in the long run but each of us must protect our systems as we see fit.
    bogiesan
  • Scott Simmons
    June 6, 2006 at 2:34 pm
    I was forced to upgrade to 10.4.6 last week when I updated FCP to 5.1. I have 1 G-RAID and I am happy to report that so far so good… no issues.
  • Arnie Schlissel
    June 6, 2006 at 3:03 pm
    [stevec] “Has anyone else had issues with 10.4.6 in anyway?”
    None whatsoever. Nada. Zero. If you have a peculiar problem that only happens with some specific type of hardware, say all of your G Raid drives going offline, but nothing else is effected (including your other FW devices), then it’s probably not the fault of the OS. It’s most likey the fault of the drive (or other device).
    Arnie
    https://www.arniepix.com
  • Stevec
    June 6, 2006 at 4:15 pm
    That’s my point to the powers that be, but they are no telling us not to download any software or updates with out checking with IT.
    Our IT department knows nothing about MAC’s.
    We are having this problem wih 1 G-Raid drive on each of our three systems even though we each have an additional G-Raid and another firewire drive.
    It doesn’t make sense that this OS upgread would only effct 1 out of 2 G-Raids and not the other firewire devices, including out AJA IO’s.
    Some people just don’t use logic.
    Steve Cohen
    Editor
  • Jeremy Garchow
    June 6, 2006 at 4:34 pm
    I know no one wants to hear this because of a good track record, but this is a problem with your GRAID. Head on over to the GRAID forum and you’ll see a long list of complaints. This exact thing happened to my AE guy and he had to send it back. Supposedly, G Technologies tracked it down to a faulty on/off switch (hence the mounting and unmounting). You probably hear a bunch of clicks and the light on the GRAID is blinking ultra fast, no? Back up your media before sending it away.
    Jeremy
  • Stevec
    June 6, 2006 at 4:38 pm
    Thank you Jeremy.
    This is exactly what I wanted to hear.
    Now I can go to my bosses with proof that it is not an issue with the OS, but with the G-Raid itself.
    Steve Cohen
    Editor
  • Ian
    June 15, 2006 at 11:44 pm
    FWIW:
    I have a fleet of graids and this same problem has only just shown it’s head. Only on 10.4.6 machines. We’ve had to manage some other tweaky things as a result of 10.4.6. Overall it is fine. The graid thing is a new one for me to chase down. I suspect it is a problem managing the FW port as it seems a particular problem on IO or DV via firewire connected equipment.
    Keep you posted.
    Ian
    Rogue Post
    HD Film Mastering
    Uncompressed Online
    Feature Film/Broadcast/Commercial
    212-366-5011
  • Stevec
    June 16, 2006 at 2:56 pm
    Ian;
    The issue is a problem with the G-Raids
    Look at this other post by Jeremy…
    Steve Cohen
    Editor
