Activity › Forums › Adobe Premiere Pro › problems when rendering clips and viewing on youtube
  • problems when rendering clips and viewing on youtube
    Posted by Accountclosed on August 20, 2007 at 3:19 pm
    Hello,
    i’m stuck. i edited a 2 minute video but when i export as a movie or export as a media encoder file, the audio is garbled on youtube upload.
    here’s my flow
    1. edit my clip. there’s alot of greenscreen so alot of rendering back and forth between premiere and ae
    2. exported all the dialog from the vid to a wav file
    3. performed cleanup of dialog in soundbooth and exported as a wav
    4. created a short music clip in soundbooth and exported as a wav
    5. layered both audio clips into premiere
    6. rendered (hit escape) and watched the vid play. it played clean.
    7. exported as movie qt h264 320 x 240
    8. play back and the dialog is super static like and the music clip is all i hear.
    so i repeated steps above but used the media encoder exporting as a qt h264 320 x 240 and the audio played fine. however when uploading to youtube, it sounded the same as the above case. please help as i’m stumped! thanks!
    https://youtube.com/watch?v=5bS0qsR5WiI or
    https://youtube.com/watch?v=lPaKigHxdNM
    equiptment
    1. premiere cs3
    2. ae cs3 trial
    3. soundbooth cs3 trial
    4. dual core hp laptop hp dv9500t
    1 gb ram, 200 gb 7200 rpm drives
    https://youtube.com/profile?user=foobar8675
    Mike Velte replied 19 years, 1 month ago 3 Members · 3 Replies
  • Steven L. gotz
    August 21, 2007 at 12:33 am
    What level do your audio monitors in Premiere Pro show? Perhaps the total of both clips is way over zero?
    Steven
    https://www.stevengotz.com
  • Accountclosed
    August 21, 2007 at 4:20 am
    hi steve, it’s between -12 and -18db
  • Mike Velte
    August 21, 2007 at 10:15 am
    YouTube recompresses the video and audio you send them which degrades both. Try increasing the audio bitrate from the default 32 to 48.
