Activity › Forums › Adobe Illustrator › Problems when I create a table. I cant align the text and the table cell
  • Problems when I create a table. I cant align the text and the table cell
    Posted by Darragh Griffin on February 27, 2014 at 8:27 am
    Hi
    When I create a table by going to Object > path > split into grid….so far so good. But when I want to type something into the table cells with the text tool… the stroke of the cell disappears.
    This leads to another problem because when I go to align tool, to center the text with the table cell, I cant seem to select both the cell and the text to align them. Of course the cell not having a stroke doesn’t make it easier!
    THanks
    Vincent Rosati replied 12 years, 7 months ago 2 Members · 1 Reply
  • Vincent Rosati
    February 27, 2014 at 9:11 pm
    I suspect that when you enter the text your turning the squares into text objects.
    Would it be possible to select the grid and Copy/Paste in Front. Lock the lower stroked grid, and type on the upper grid?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
