Activity › Forums › Apple Final Cut Pro Legacy › problems viewing Full HD
  • problems viewing Full HD
    Posted by Gabriel Angel on February 22, 2013 at 2:42 pm
    I am having problems viewing Full HD on my Macbook pro 2.4Ghz 4GB ram, 17 inch (1920 x 1200 ) and have installed OSX Snow Leopard 10.6.8.
    I use a hacked Gh1, and the story of how the problems occurred is as follows:
    6 months ago everything worked fine, I was able to view the AVCHD (.mts files) with VLC player, and the conversion in FINAL CUT PRO 7 to Proress LT worked fine, and I was also able to see the exported Proress in QT player smoothly.
    A day my the charger for the laptop stopped working, probably because of an unequal flow of electricity, and simultaneously the battery died.
    After that event I have not been able to view Full HD anymore…
    The .MTS files opened but remained blocked after 2 seconds, and only the sound was heard.
    The Proress LT files could be seen in QT player but not smoothly. Very annoying.
    I bought another charger so that I could use the laptop again, and now a big detective work started:
    1. I made a Apple hardware test on the computer to cheek if it could be the NVIDIA GeForce 8600M GT that caused the problem, but according the test everything was working well.
    2. I made a ram test, all in order
    3. I tested the harddisk at western digital service center, and it is working fine
    4. I reinstalled Snow Leopard with the same settings and programs as before the accident, and no change, still problems. I tried Lion and still the same.
    5. I went to a mac repair shop that booted from an external harddisk and still the same problem with the files as on the osx installed on my own computer.
    5. I made a trash preferences with preference manager and no change
    6. And I will mention that I have tried with many different files, so it is not one corrupt file that is the problem.
    7. I also experience problems in viewing the files that I have compressed via MPEG Streamclip or in Cmpressor, they often also docent run smoothly, problems that did not occur before.
    Any suggestions?
    Gabriel Angel replied 13 years, 7 months ago 2 Members · 7 Replies
  • 7 Replies
  • William Carr
    February 25, 2013 at 7:54 pm
    Are you playing back the media from an external? Via USB or Firewire?
    FWIW after new OS installs I have sometimes had problems playing back various compressed codecs that played fine before. But it’s odd that ProRes would be problematic unless your media is on your system drive.
  • Gabriel Angel
    February 26, 2013 at 1:08 pm
    my media is on my system drive, I will test in on an external drive with FW 800, but it worked fine like this previously.
  • Gabriel Angel
    February 26, 2013 at 1:20 pm
    I tested on an external drive and the problem is the same, and yes it is ProRess
  • William Carr
    February 26, 2013 at 10:16 pm
    So is the only aspect different than when everything worked great, that the internal battery is dead and you are using a new AC adapter? Is the AC adapter an Apple model, new?
  • Gabriel Angel
    February 27, 2013 at 7:12 pm
    Yes I use an original apple MabSafe charger.
    Today I tested the laptop with a battery that is functional, and it seems that that was the issue, it played the Full HD video much better like that, it seems that it needs both energy from a charger and the battery simultaneously in order to play HD video
  • William Carr
    February 27, 2013 at 9:37 pm
    It feels so satisfying to have a problem resolved!
  • Gabriel Angel
    February 28, 2013 at 11:38 am
    thats true 🙂
    good to remember…I was still a little disappointing that it didnt work without battery, but indeed its a good feeling
