Activity Forums Adobe Premiere Pro Problems using PHYX Keyer
  • Problems using PHYX Keyer
    Posted by Rui Manuel on December 17, 2015 at 4:38 pm
    Hello there.
    I am eager to buy the PHYX Keyer Plugin Suite, but even after seeing the tutorial videos I can’t get anything but very poor results.
    I am sure I am doing something wrong, but can’t see what it is. I am using the TRIAL version 5.2 now, but really need to buy it.
    Here are some details:
    1 – I am using Adobe Premiere Pro V 7.2.1
    2 – Under Mac OSX Yosemite V 10.10
    I attach some image that shows the best I could get until now.
    What am I doing wrong? I already have tried all the possible configurations on the plugin, and these are the best I could get after trying all the possibilities.
    Can somebody please help me on this?
    Thank you so much in advance.
    Rui Manuel replied 10 years, 8 months ago 3 Members · 4 Replies
  • David Roth weiss
    December 17, 2015 at 5:27 pm
    What is your prior experience with keying?
    Are you trying to do everything, including the hair with a single instance of the plugin?
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Rui Manuel
    December 17, 2015 at 5:35 pm
    David, thank you for answering me.
    I am not an expert in keying, I use a technique abour 1 year now. And yes I know I can use multiple instances of a plugin.
    but in this case all the tutorials I saw it is just a single click and after that one or two minor adjustments do get it right.
    in my case I cant get it right my no way, not even close!
    thats why I am feeling lost here.
    can you please help or suggest something? :/
  • Philippe Lessard
    December 18, 2015 at 3:19 pm
    First, what kind of footage it is?
    In case its H264 or any “compression codec” you will have trouble keying, especialy with the kind of footage you have(with a lot of hair around her head)even with professionnal tool, those shots are difficult.
    The first thing to do is re-export your footage in 4444, prores 4444 or Animation codec will do it (not magic, but could help).In your screencap I see it in the plugin window, “reconstruction sampling”try to put it to 4444.
    You shouldnt key in Premiere, do it in after effect instead, with keylight.
    Before buying this pluging I will test the other included such as Ultrakey, and you should try the Keyer from Phyx not the Fast keyer…Always do your key in 100% resolution. Watch a online tutorial about keying.
    Consider reshooting your talent with a tight ponytail, no hair messing around.
    But you really should watch a online tutorial about keying…
    Good luck
  • Rui Manuel
    December 20, 2015 at 9:43 pm
    Thank you so much for your answer and kindness. 🙂
    I will consider now all the points you referred to.
    rui
