Activity Forums Apple Final Cut Pro Legacy problems upgrading FCP 6 to FCP 6.0.4
  • problems upgrading FCP 6 to FCP 6.0.4
    Posted by Zoee Blue on July 8, 2010 at 4:55 pm
    Hello there,
    I have an intel IMAC core 2 duo with FCP 6 installed.
    I am trying to upgrade my FCP6 to 6.0.4 but when doing the installation is says “You cannot install Pro Applications Update 2008-02 on this volume. Your computer does not need this update”
    Any ideas way?
    Many thanks,
    Zoee
    Chris Guevarra replied 16 years, 1 month ago 3 Members · 6 Replies
  • Shane Ross
    July 8, 2010 at 6:23 pm
    Use the SOFTWARE UPDATE to do this. You might be missing some component that is needed before that one. Oh, but you don’t want to go to FCP 6.0.6 do you?
    Shane
  • Chris Guevarra
    July 8, 2010 at 7:24 pm
    Hey Zoee,
    Yeah, unless you don’t want to go any higher than 6.0.4 then I would just do a software update from the Apple Menu.
    If that doesn’t work, it might be something with the hard drive that you are trying to install the update to.
    Chris Guevarra
    massmovementtv.blogspot.com
  • Zoee Blue
    July 9, 2010 at 1:03 am
    Thanks for the quick reply!
    When I do the Software update from the apple menu it doesn’t show I need to upgrade my FCP6 at all.
    Zoee
  • Shane Ross
    July 9, 2010 at 1:25 am
    What version are you currently running? In the Final Cut Pro menu, choose ABOUT.
    Shane
  • Zoee Blue
    July 9, 2010 at 2:11 am
    I am running FCP 6.0
  • Chris Guevarra
    July 10, 2010 at 1:01 am
    Hmmm… I did some research for you and found this. Hopefully this helps:
    “…The support guy told me that the only way to update is to use the OS X software update utility. So I’ll have to connect it to theinternet. :S
    I will have to do that for both Leopard and Tiger Macs.”
    -from macosx.com forums
    Forum link:
    https://macosx.com/forums/mac-os-x-system-mac-software/303186-where-do-i-find-fcp-update-v-6-0-4-a.html
    Chris Guevarra
