Activity Forums Adobe Premiere Pro Problems transferring project to new machine – render files
  • Problems transferring project to new machine – render files
    Posted by Garnet Campbell on November 9, 2012 at 6:00 pm
    I like to know the proper workflow to transfer a project between different workstations. I started editing my project on my laptop. All the project files are on an external drive. I simply wanted to connect that external drive to my imac and continue editing.
    When I connected the HD to the imac Premiere couldn’t find the rendered files because I had originally set the render files location to the local HD on my laptop. I understood why this happened but why cant I just re-render those files now that its on a new machine?
    I reconnected my project to the original laptop… then changed the render files location to the external HD. I rerendered the entire timeline, then reconnected back to the imac. Great the images all showed up. I thought the problem was solved, but as soon as I applied a new effect settings to that footage premiere could not locate the original files.
    This is a really common practice to edit a project on different workstations, how are people dealing with this?
    Chris Borjis replied 13 years, 10 months ago 3 Members · 2 Replies
  • Joseph W. bourke
    November 9, 2012 at 7:18 pm
    You might want to take a look at PPro’s Project Manager, which was created to allow for transportable projects. Here’s a tutorial on which will help you decide whether it will work for you:
    https://library.creativecow.net/articles/harrington_richard/Premiere-Pro_Project-Manager/video-tutorial
    There are lots of options in the Project Manager, including the ability to move preview files, which seems to be your problem.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Chris Borjis
    November 12, 2012 at 6:19 pm
    I always set everything to follow the projects folder.
    In my case, everything is on a RAID5 array.
    All clips, graphics, audio and render previews go in that single project folder.
    I’ve had no problems moving them from one system to another.
