Activity Forums Avid Media Composer problems to copy to tape
  • problems to copy to tape
    Posted by Cristian Badilla on February 6, 2006 at 12:02 pm
    I use Avid express 3.5 in my HP laptop. I have a Sony GV-D100E (PAL) DV player. When I export the timeline to tape the video in the tape is with a lot of artifacts and “noise”? It looks like a Codec problem. Does anyone knows if I have to install a codec in my computer to be able to copy to tape?
    Best regards,
    Badilla
    Cristian Badilla replied 20 years, 6 months ago 2 Members · 3 Replies
  • Jon Zanone
    February 6, 2006 at 12:10 pm
    What resolution did you bring your video in? Do you have the little blue button on? You’re coming out of firewire I assume? Are you using a converter (we had a box to convert firewire to analog video…)?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Cristian Badilla
    February 6, 2006 at 8:25 pm
    Hi Jon.
    The broght the video in via the same DV player. Is DV , and yes, it’s connected via firewire. I don’t think I need any converting box, it’s digital to digital, isn’t it?
    I looked at the time line and the “little buton” is green. I was redaing about this togle real time on off and I don’t really get it. Is green for real time efcts on, right? Do I have to have it off (blue) to export via firewire?
    Badilla
  • Cristian Badilla
    February 7, 2006 at 7:54 am
    Got it. he thing is when conected thru firewire I have to set the AV in the deck as “off”, allas, it only works as digital in. Why? No idea.
    Badilla
