Activity › Forums › Apple Final Cut Pro Legacy › Problems Setting up 640×360 Project/Sequence
  • Problems Setting up 640×360 Project/Sequence
    Posted by Steve Crow on March 9, 2008 at 9:16 pm
    I am having trouble setting up a FCP 5 project so that I can edit and export in 640×360 (16:9) 24fps format. The basic issue is that I am getting letterboxing of about 80 pixels wide on the right and left side of the video.
    I have 80 pixel wide letterboxing visible on both the right and left sides of the canvas window too and when I try to export the video at 640×360 – that letterboxing remains.
    My MacBook Pro was taking forever to render my clips at their full 1920x1080i resolution which I captured from my HV20…so I thought I would try exporting those clips out at 640×360 and then re-importing them into a new timeline set up at 640×360 so that, hopefully, the rendering and editing wouldn’t be as demanding on my machine.
    I tried setting up a new project and sequence setting and I think here’s where I made my mistake.
    My Project Settings are (customized)
    Frame Size: 640×360
    Editing Timeline 24fps
    Field Dominance NOne
    Pixel Aspect Ratio HD (1440 x 1080)
    Anamorphic: 16:9 Off
    Compressor: HDV 720p24
    Millions of Colors
    My Sequence settings are:
    Frame Size 640 x 360
    Aspect Ratio Custom (16:9)
    Pixel Aspect Ratio (1440 x 1080)
    Field Dominance: None
    I appreciate any assistance you can offer. Thanks!
    Steve
    Steve Crow replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
