Activity Forums VEGAS Pro Problems Rotating a clip in VEGAS 5 Track Motion…?
  • Problems Rotating a clip in VEGAS 5 Track Motion…?
    Posted by Bryan Michael block on April 6, 2005 at 6:09 pm
    Hey gang,
    I am trying to rotate a clip (spin on it’s center) in VegasPro 5, but any degree rotation I enter above 180 degrees reverts to a negative number and it rotates the clip the oposite way in which I want to spin it. For example If I put in 180, it works fine. If I put in 190 it reverts to -170 (the compliment to 190 to make 360 ( a full circle)) and it rotates the clip in the oposite way- Is there a setting I am missing here? What gives?
    Any help would be appreciated-
    Bry
    Graham Bernard replied 21 years, 5 months ago 3 Members · 5 Replies
  • Edward Troxel
    April 6, 2005 at 6:22 pm
    I just added a clip to a new project, opened Track Motion, typed in 190 for the rotation, and it took. I then typed in 390 and it took, and 590 took, and 790 took, and 1090 took.
    What else did you change in Track Motion?
    Edward Troxel
    JETDV Scripts
  • Graham Bernard
    April 6, 2005 at 9:50 pm
    Had you previously experimented using Pan/Crop? Just check this out for me. Make sure you haven’t inadvertedly left in any Key Frame diamonds. Only a thought.
    Grazie
  • Bryan Michael block
    April 7, 2005 at 11:17 am
    Thanks for the replies.
    I opened a new project and sure enough any entries of numbers higher than 180 work FINE!
    But in the project I am working on…they still revert to negative complimentary numbers when I reach above 180! 🙁 ???
    There must be some kind of setting for this, an option or something I’m not seeing.
    Anyone have any insight into WHY this is happening? I’d just like to understand it at this point.
    Thanks-
    B
    April 7, 2005 at 11:29 am
    OK-
    I figured it out…this is embarassing, but it goes to show you that sometimes you can convince yourself that what you are seeing is what you are seeing, when really you are seeing something else.
    Opening the new project as I stated, I easily entered numbers into the rotation box and got all the spinning I wanted…
    Opening the old project again, I kept changing those numbers and they kept reverting back to negative compliments to 360! OR SO I THOUGHT. After careful study of everything I was seeing I realized that I was putting these numbers into the ORIENTATION box and not the ROTATION box!!! :-0
    They look alot alike and are right on top of each other- but I was so convinced that I was putting them in the right box, I didn’t notice it was the “Orientation” box. Opening a new project, with a clean slate- it was easy to put them in the right spot and cleared my vision as to what I was doing.
    Thanks guys
    B
  • Graham Bernard
    April 7, 2005 at 11:36 am
    Easily done. How are you with ATMs ? 😉
    Grazie
