Activity › Forums › Apple Final Cut Pro Legacy › Problems rendering
  • Problems rendering
    Posted by Jeneene on July 20, 2006 at 8:32 pm
    Hello,
    My FCP will not render anything. There is no error message it just doesn’t do anything. I am running FCP 5 on MAC OSX dual 2.0 with 1.5GB of ram, projects are on external HD. This just started about a month ago, an I’ve had the system for about 5 months.
    Any tips?
    Jeneene
    Jeneene replied 20 years, 2 months ago 2 Members · 2 Replies
  • Captain Mench
    July 20, 2006 at 10:54 pm
    Try Option-R…
    If that works… well then it has to do with a few things… how your RT settings are set up and how your render settings are set. Apple-R will render only those colored lines that you’ve told to to render… or the defaults I think are anything above green. So go to Sequence – Render… and click a few extra colors. Those will now render too when you press Apple-R.
    Good luck,
    CaptM
  • Jeneene
    July 21, 2006 at 5:16 pm
    Thanks so much but I already tried that. any other ideas?
