Activity › Forums › Adobe After Effects › Problems rendering with Zaxwerks and Nucleo
  • Problems rendering with Zaxwerks and Nucleo
    Posted by Scott Thomas on June 27, 2007 at 7:22 pm
    Has anyone else seen this:
    I have created a scene which includes imported 3d objects (3DS) via Zaxwerks Invigorator Pro. I have given them a metallic surface using one of Invigorators preset materials.
    When I render these objects using the Nucleo plug-in they turn black for just one frame in every second or so. The effect is not constant but does appear on every metallic object. Other imported 3D objects within the scene without reflected materials render perfectly.
    If I render with Nucleo disabled they render out perfectly. Whether this is a Nucleo or Zaxwerks problem I’m not sure – any ideas?
    This post is also in the Zaxwerks forum.
    Scott Thomas replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
