Activity › Forums › RE:Vision Effects › Problems rendering Twixtor in Premiere Pro 2
  • Problems rendering Twixtor in Premiere Pro 2
    Posted by Hernan Vilchez on February 12, 2007 at 7:23 pm
    Hi, Im newbie with Twixtor. I cant see image when rendering with Twixtor 4.5 in Premiere Pro. I make all the steps suggested: put the original footage in a sequence plus universal counting, then i nest this sequence in another (where i have the rest of the footage) and apply twixtor. 25p timeline, “none” in input fields, the original clip was deinterlaced in After Effects with fieldskit. The rest of the footage is progressive (thats why a 25p timeline)
    I
    Hernan Vilchez replied 19 years, 7 months ago 2 Members · 3 Replies
  • Hernan Vilchez
    February 12, 2007 at 8:01 pm
    Tried with interlaced timelines, no problem. The red footage comes only with progressive timelines in Pemiere Pro. Is Twixtor not working with progressive projects?? Please some help…
  • Pierre Jasmin
    February 12, 2007 at 9:07 pm
    Can you send me a Project with a 1 second clip so I can look at it
    techsupport@revisionfx.com
    Red Footage would be indication of something not the same res
    Pierre
  • Hernan Vilchez
    February 13, 2007 at 1:03 am
    Pierre, u where right, a mismatch of res. My fault.
    Anyway, ive tried in the same 25p project to deinterlace applying fieldskit to a nested seq (that has the original 25i footage plus univ count) and to that i apply twixtor (as i read in one thread here) and comes some really bad footage.
    But if i first deinterlace in after fx and then apply twixtor to the rendered footage (now progressive)in the premiere timeline, i get some beautiful slo mo. Same settings in both plugins (2x duration in fielskit / input fields: none in twixtor). Im wrong again? I will send u the premiere project tomorrow (too late for me now)
    Thanks for your quick and precise answer, Hernan
