Activity Forums VEGAS Pro Problems rendering Quicktime to DVC PRO-HD 1080i
  • Problems rendering Quicktime to DVC PRO-HD 1080i
    Posted by Herman Lira on June 4, 2008 at 6:50 pm
    I just started working as an editor with a small produciton company which edits small ads for broadcast TV, both in SD and HD.
    My problem right now id that I need to export my time line which is HD source video (shot in HD, format = H.264, Attributes: 1920x1080x24) to QuickTime DVCPRO HD (1080i) format.
    When I select the above default settings in Vegas 8, the colors of the output video are much darker than what i see in the time line! I have tried playing with may parameters in the render/custom section, but no luck!
    Can you please help me with this?
    Herman
    Herman Lira replied 18 years, 3 months ago 2 Members · 4 Replies
  • Douglas Spotted eagle
    June 4, 2008 at 7:51 pm
    Where are you viewing the content? Only in Vegas? or in Windows Media Player or other external player? Gamma varies from player to player, which is in all likelihood causing the perceived shift in chroma value.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Herman Lira
    June 4, 2008 at 8:08 pm
    I’m viewing the content in Vegas video preview and other players such as Quicktime and Windows Media Player. As the content is rendering, it shows frame by frame what the output should look like and it’s coming out darker than it should.
    Is there any way to fix this problem? Unfortunately, switching to .m2t is not an option. The network requires the format to be .mov.
    June 4, 2008 at 8:13 pm
    if you’re seeing the render darker than it should be in Vegas preview, the problem is in your project settings (32bit, perhaps?) If it appears correctly in Vegas but not QT or WMP, the problem is in the gamma set up of your computer and/or player.
    VASST
  • Herman Lira
    June 4, 2008 at 8:59 pm
    Hi Douglas,
    I solved the problem by changing my project settings from 32-bit to 8-bit and it fixed the problem. Thank you for all your help.
