Activity Forums Boris FX Particle Illusion Problems Rendering Large format
  • Problems Rendering Large format
    Posted by 4crites on April 15, 2006 at 10:15 pm
    I’m using PIllusion v3.03 on a Dual 2.5 Ghz G5 with 4 GB RAM. The NVidia card I have
    supports a maximum texture of 4096×4096. When I rendered a grenade hit using software only
    at 3000×4000 the particles rendered sucessfully but everyting was scaled down and in the left lower corner of
    of the 3000×4000 frame. I need elements this size for a program that I am doing that is 1920×6000. Any ideas anyone?
    Alan Lorence replied 20 years, 4 months ago 3 Members · 5 Replies
  • Elvis Deane
    April 16, 2006 at 4:19 am
    Were you rendering in particleIllusion, or in pIllusionRender? If you’re doing it in particleIllusion, it’ll only render out as large as your desktop’s maximum size. For a size that big, you’ll most likely have to use pIllusionRender.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • 4crites Create COW Profile Image
    4crites
    April 16, 2006 at 4:47 am
    I was using Particle Illusion Render. I had read about the desktop size limitation. Thank you for your rapid response Elvis.
  • Alan Lorence
    April 17, 2006 at 8:21 pm
    Try turning off the OpenGL hardware acceleration — click the ‘Options’ button (pIRender for OS X).
    Alan.
    wondertouch
    4crites
    April 19, 2006 at 6:11 pm
    Alan,
    I did have it turned off, I’ve since tried several other files with consistent results. They all render small and in the lower left hand corner. Thanks
  • Alan Lorence
    April 19, 2006 at 7:24 pm
    Is this a complex project? If so, try to make it as simple as possible, make sure it still has the problem, then zip it and send it to wondertouch support.
    Alan.
    wondertouch
