Activity › Forums › Adobe Premiere Pro › Problems Rendering in Quick Time Pro.
  • Problems Rendering in Quick Time Pro.
    Posted by Apuat on March 16, 2007 at 8:22 pm
    Whenever I render a project using the QuickTime Pro codec and the resulting file is 4gigs or larger I get an error message. I render files which turn out to be 4gigs and larger all the time. This only happens with Quick Time. Any ideas haw I can remedy this?
    Apuat
    Apuat replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mike Velte
    March 17, 2007 at 11:06 am
    Windows does not support files larger than 4 GB unless they are “Open-DML”. You did not say which codec you used but the Animation and DV codecs are Open-DML.
  • Apuat
    March 17, 2007 at 8:32 pm
    Yes I’m using the QuickTime Animation codec. With QuickTime 7.1. Ironicly After Effects will render QT files larger than 4 gigs but I need to render directly from P.Pro.
