Activity Forums Adobe After Effects Problems Rendering a PAL 4;3 source to PAL 16:9
  • Problems Rendering a PAL 4;3 source to PAL 16:9
    Posted by Smoran on November 15, 2006 at 9:29 am
    I am trying to create a DVD in PAL widescreen using 4:3 avi source.
    I have made a Composition with
    – Preset – PAL D1/DV Widescreen 720×576
    – Pixel Aspect Ratio – D1/DV PAL Widescreen (1.42)
    The source is 720×576 D1/DV PAL (1.07) AVI file
    I have tried rendering to avi, quicktime & MPEG-2 and each time it creates a 4:3 file resulting in vertical stretching.
    The same issue occurs when I don’t use any video and just jpg & png files.
    Any advice would be gratefully received
    Smoran replied 19 years, 10 months ago 2 Members · 4 Replies
  • Steve Roberts
    November 15, 2006 at 3:47 pm
    Drag the 4:3 footage onto the 16:9 comp.
    Hit ctrl-alt-shift-H to make the footage match the width of the comp. It will now be cut off top and bottom.
    If you want to see it look wide and normal, hit the pixel aspect ratio correction button at the bottom of the comp window. However, the rendered file will look slightly stretched, but it must be cut off top and bottom. There’s no way around that: 16:9 is not 4:3.
  • Smoran
    November 15, 2006 at 6:20 pm
    Thanks for that advice.
    However – when I rendered the result it produced an AVI that, when viewed, was 4:3 but with vertical stretching. So somewhere in the rendering options it is producing a 4:3 file.
    The render settings are:
    – Qlty – best
    – res – Full
    – Size – 720 x 576
    – Output Module – Lossless
    – Format – Video Windows Movie
    – Final Size – 720 x 576
    I have since tried changing the Output Size to a 16:9 aspect lock (manually input) .. and this seemed to do the trick.
    Do you know what the size width value should be for PAL widescreen without the slight balck bar down the sides?
    What format should I render it to in order to get the best dvd quality .. and which file format for importing into a DVD archtecting paackage? … sorry for going off-piste a little
  • Steve Roberts
    November 15, 2006 at 8:22 pm
    Okay. Files for TV, DV, or DVD are supposed to look a little squeezed on a computer, because those files contain non-square pixels, and computers display square pixels. A software DVD player converts everything to square pixels, so it looks right on a computer.
    Search the COW tutorials for an article by Rick Gerard on non-square pixels for an explanation.
    You need to drag the video into a PAL DV widescreen comp preset. Shift-scale the video so it fits the width of the comp — you will lose material at top and bottom. If you want it to look “normal” while you work, hit the PAR correction button as I wrote. Render to an uncompressed AVI, then use a DVD authoring app (such as Adobe Encore DVD) to compress to MPEG-2, then author the DVD in the authoring app (set the 16:9 flag according to the app’s instructions), then burn it.
    It will look fine on a TV. You must test your DVD on a TV.
  • Smoran
    November 16, 2006 at 11:37 am
    SUCCESS!!!!!
    The key was to change the Output Module Settings for Strecth to 1024×768 and then manually stretching the video (proportinately)
    Obviously there is the compromise as it reduces the qualtiy a little but fills the HD screen nicely, and also there is editing work to make sure that the vid is moved to maintain key areas of the video in the “safe” area.
    What I will do is create DVD’s with widescreen and 4:3 options … one full screen the other better quality.
    Thanks for your patience and the help
    PS I read Rick’s tutorial …. it was his comments that PAL should adjust automatically that triggered the final solution…. so again – thanks
