Activity Forums Apple Final Cut Pro Legacy Problems reinstalling Final Cut Pro 7 with Snow Leoaprd
  • Problems reinstalling Final Cut Pro 7 with Snow Leoaprd
    Posted by Simon Moorhead on October 11, 2016 at 5:33 pm
    Hi There,
    I have a an old Mac Pro 2008 running Final Cut Studio 7. All was ok until I stupidly updated the OSX to Yosemite-disaster.
    I made a Carbon Copy Cloner of the drive, then reinstalled Snow Leopard, which luckily I have on disc. I then copied the drive’s documents over using Migration Assistant.
    Everything seemed to copy fine, but whenever I try to open Final Cut Pro, it immediately shuts down with this message
    I have updated the OS to 10.6.8, but the same message appears.
    I then tried reinstalling Final Cut Studio-the same message appears.
    Please can anyone help or advise?
    Shane Ross replied 9 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    October 11, 2016 at 5:49 pm
    You cannot MIGRATE the application over, that misses a lot of the small files installed in the SYSTEM and LIBRARY. And yes, I noticed that you said you installed it again…but that was over a migration…might be part of the issue. Use the FCS REMOVER from digitalrebellion.com, and then install again.
    Remove the app. Then run DISK UTILITY to Repair Permissions, then install FCP
    Shane
    Little Frog Post
