Activity Forums DVD Authoring Problems playing burnt DVDs from Studio Pro
  • Problems playing burnt DVDs from Studio Pro
    Posted by Sarah Bright on May 26, 2011 at 9:57 am
    Hi guys…
    Having some problems playing a certain film that has been made through DVD Studio Pro…
    It’s an hour programme that we have exported from FCP and run through compressor using the ‘DVD: Best Quality 90 minutes’ setting.
    Then running through DVD Studio Pro.
    The original file is DVCProHD 1080i50 BUT we’ve also used a DV Pal version too.
    Basically the DVDs skip, or judder and stop playing. Usually about half way through, but sometimes just at the beginning.
    We’ve redigitized the tape and made a new QT and repeated the process.
    We use Verbatim DVDs and don’t have any problems with other projects.
    We just bought some JVC DVDs.
    Ay suggestions welcome!
    Eric Pautsch replied 15 years, 3 months ago 2 Members · 6 Replies
  • Eric Pautsch
    May 26, 2011 at 12:45 pm
    What were your bitrate settings and did you use ac3 audio?
  • Sarah Bright
    May 26, 2011 at 2:16 pm
    Yeah, sorry… it is AC3.
  • Sarah Bright
    May 26, 2011 at 2:18 pm
    Currently 192kbps, The DVD uses Dolby Digital Professional 2.0 and MPEG-2 6.2Mbps 2-pass.
  • Eric Pautsch
    May 26, 2011 at 2:29 pm
    Right but it helps to know the exact settings. Look in the inspector for Compressor. Keep the peak setting under 8 if you can
  • Sarah Bright
    May 26, 2011 at 2:45 pm
    Peak setting for which? And where do I change it?
    In the Mpeg-2 settings, the Average Bit Rate is set to 6.2Mbps
    And the Maximum Bit Rate is 7.7.
  • Eric Pautsch
    May 26, 2011 at 3:26 pm
    Yes….the max setting is fine. Throw away the jvc discs and try another batch. Have you tested on more than one player?
