Activity Forums Adobe Premiere Pro Problems pausing timeline playback
  • Problems pausing timeline playback
    Posted by Cassandra Chowdhury on May 25, 2010 at 11:54 pm
    I am currently using Adobe Premiere Pro CS5 to edit a music video shot on the 7D (files converted using Cineform). Numerous times when I have attempted to play the timeline, pausing playback becomes impossible. The timeline’s picture will freeze, but the audio will play all the way to the end of the timeline and as soon as it does, it crashes Premiere.
    I had a similar problem with CS4 a while back, and it had to do with a faulty sound card in my machine. I know that’s not the issue now but I do have a feeling it has something to do with the asio settings or some other audio settings in CS5. Has anyone else had this problem?? It’s crashing so often I can’t finish this video till I resolve the issue. Thanks!
    Cassandra Chowdhury replied 16 years, 3 months ago 3 Members · 10 Replies
  • 10 Replies
  • Jon Barrie
    May 26, 2010 at 12:20 am
    If your system is not too under=par you should be able to edit with the 7D footage directly without the Cineform conversion. I would think the cineform plugin is causing the instability not CS5 itself. I have a Canon 550D (t2i) and that is using the same video specs as the 7D. I have had a great time cutting it on my macbook pro C2D 2.66 4G ram. CS4 was no good for editing the native files, but CS5 eats it up.
    – Jon Barrie 🙂
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Patrick Zaw
    May 29, 2010 at 7:41 am
    I have the exact same problem right now. I do notice it happens on parts where I have heavy grading using Magic Bullet Looks 1.4. If I turn off the grading effects the playback will not crash.
    Open a support case with CineForm which I’ve done too. Instead of playing back, use Adobe Media Encoder and encode your project. It should fail at a certain point and email them your error code. Here is the error I get. Can you post your error too?
    Problem Event Name: APPCRASH
    Application Name: PProHeadless.exe
    Application Version: 0.0.0.0
    Application Timestamp: 4bb5379d
    Fault Module Name: CFHDDecoder64.dll
    Fault Module Version: 6.2.4.455
    Fault Module Timestamp: 4bf34696
    Exception Code: c0000005
    Exception Offset: 000000000009253e
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional Information 1: 7b92
    Additional Information 2: 7b926bd68eb3581f07974510a190f3eb
    Additional Information 3: 4214
    Additional Information 4: 42148571ab0d2490b498705fda9d06a5
  • Cassandra Chowdhury
    May 29, 2010 at 6:23 pm
    Yes, I have come to a similar conclusion about Magic Bullet Looks 1.4. Do you use an ATI graphics card? I was able to speak with Red Giant, and they told me that it was probably a combination of my graphics card, CS5, and Looks that was the problem. They offered no solutions.
  • Patrick Zaw
    May 29, 2010 at 8:27 pm
    I have a nvidia geforce gtx 275. I believe it’s a problem with cineform. If you see look at the error closely it’s coming from cineform decoder. Also I have no problems grading other codecs with MBL. Please open a case with cineform so hopefully they make it a priority since the issue seems to replicable. My case is still pending a resolution.
  • Patrick Zaw
    June 2, 2010 at 6:42 am
    I’ve done more testing without using Magic Bullet Looks. I’m only doing some effects within CS5, specifically a gradient type effect, and I get the same error when applying it. If the effect is turned off there is no problem.
    I think the issue is when a gradient type effect or vignette is applied. It consitently happens to me.
    If you want to replicate this yourself this is what you can do in CS5:
    1) add a video effect – Generate – Circle
    2) blending mode shoudl be NORMAL
    3) set it to “invert circle”
    4) set the Color to black
    5) set opacity to 50%
    6) apply a large radius
    7) set the feather to a larger amount so there is a nice gradient effect
    This creates a vignette effect and should have a nice gradient to black. I’ve applied the exact same effect to any other codec and i have no problems, only CineForm codec errors on me. I have no other effects but this gradient effect.
    Still no work around for me. How have you worked around the issue? If it doesn’t get resolved soon I’m going to have to deal with very large mezzanine files in MPEG2 or something stable.
    June 2, 2010 at 9:43 am
    I have been using raw .mov’s straight out of the 7D. For some reason they need to reconform constantly, which is a bit of a slowdown, but they take color/gradient effects ok. I am still dealing with very frequent crashes however. So there’s no real solution I have found!
  • Patrick Zaw
    June 4, 2010 at 9:08 am
    Seems like the recognize the problem. Check page 2 of this thread and try the new importer.
    https://www.dvinfo.net/forum/cineform-software-showcase/479612-cineform-cs5-encode-issues-2.html
  • Patrick Zaw
    June 4, 2010 at 9:21 am
    Just tried with the new CHFD_AVI_Importer.prm and it worked like a charm! I’m able to stick to my original workflow now. I’ve tested MBL on the native h264 vs cineform and I can tell realtime the processing with be much smoother with CineForm. Hope this helps you Cassandra.
  • Patrick Zaw
    June 5, 2010 at 1:22 am
    NeoScene 5.0.3 just came out today and all my CS5 issues are fixed now.
    https://techblog.cineform.com/?p=860
    June 6, 2010 at 4:08 pm
    Sounds excellent, thank you all for your help!
