Activity › Forums › Apple Final Cut Pro Legacy › Problems panning audio tracks….Please help!
Posted by Gbellnz on October 27, 2005 at 8:21 pmAm having problems with audio tracks. For example: when capturing a clip where a person is talking, there would be 2 tracks of audio – one a radio mic (Track 1) and another mic (Tack 2)capturing ambient sound. I often delete the ambient track (Track 2) and am left with the the main audio from a radio mic (Track 1).
The problem is when I open up the main audio track (Track 1) and pan the track from -1 to 0. It says it has done it but the sound still comes out of 1 speaker instead of both.
It is a very recent problem that I wonder may be something to do with preferences or settings.
We have had no problems with the speakers at all.
Thanks very much,
Geoff
Alexander Kallas replied 20 years, 11 months ago 5 Members · 8 Replies -
Bouncing Account needs new email address
October 27, 2005 at 10:26 pmThe first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
Next:
THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
“Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”Click the following link for instructions.
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
There are versions for FCPro & FCExpress.Download these free Apple Scripts at
https://fcprescue.andersholck.com/
This is one FCP tip that has helped in hundreds of “odd” problems.
Gbellnz
October 27, 2005 at 11:05 pmIts still happenning, it’s like the pan function’s been disabled.
October 27, 2005 at 11:37 pmJust to make SURE your audio is working from both speakers,
DUPLICATE the Channel 1 audio and put it on Channel 2 as well.To do this, click on the ch. 1 clip and hold down both “shift” and “option” and drag the clip to ch.2 (you’ll end up with identical clips on both tracks).
See how that plays.
Adjust the pan controls on either clip and test again. -
Gbellnz
October 28, 2005 at 4:48 amYea have duplicated Track 1 onto track 2 and now track one will only go left and two will only go right. What gets me however is that you shouldn’t have to do this. I should be able to have a single track and be able to pan it to 0 and have it come out of both speakers!Voice’s should only be on a single track and music should be on two.
Anyone else got any thoughts?
Jeremy Garchow
October 28, 2005 at 4:56 amSelect he clip and hit option-l this will “de-stereoize” it :^) The clip should now be mono.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
October 28, 2005 at 11:25 am[gbellnz] “I should be able to have a single track and be able to pan it to 0 and have it come out of both speakers!”
Be patient. This process needs to be a dialog.
My guess is that you have the audio outputs set incorrectly.
Click once on the Timeline window.
Hit Command (apple) and 0 (zero) to open the “Sequence Settings” window.
Choose “Audio Outputs” tab.
Click on “Load Audio Outputs Preset”
Choose “Default Stero Preset”.This should give you the settings
Outputs: 2
Grouping: StereoGive that a try and please post back. We’ll get there.
Walter Biscardi
October 28, 2005 at 11:33 am[gbellnz] “The problem is when I open up the main audio track (Track 1) and pan the track from -1 to 0. It says it has done it but the sound still comes out of 1 speaker instead of both.”
Just place the single audio track in your timeline and go Modify > Audio > Pan Center. If you’re trying to pan to Center in the Viewer, this never seems to work all that well, easier to do it in the timeline.
For what it’s worth, I’ve found that panning a single audio track to center never sounds as good as two audio tracks panned left and right. You lose some tonal value when you split one channel across two channels. I always copy the single audio track and paste it into Channel Two, then pan then left and right.
Walter Biscardi, Jr.
https://www.biscardicreative.comNow editing “Good Eats” in HD for the Food Network
Alexander Kallas
October 28, 2005 at 12:22 pmHi Walter,
Does it really mater if we are going to A-Pac for DVD with 2/0(L,R) ?
Cheers
Alexander
