Problems on P2 copying—but not FCP importing?
Here’s a wierd one.
I am an HVX owner and as such I am trying to learn everything I can about workflow and the post situation with P2. I’m a longtime DP, film and HD, and for me this is like showing up for a shoot with the camera–and also the lab. But I digress.
I have a long project coming up this month. The producer and I have been talking and are testing our workflow. In the field our footage will be copied to FW hard drives and backed up. The question is how. One option is to go directly to FCP as that’s how the show will be edited. However the current recommendation from Panasonic and Apple (and everybody else) are to take the footage, oops, data, to our HD storage as direct copies of the card material rather than having them converted to QT by FCP. I understand why this is better…however today I found this creating its own issues…
Today I sat down at my computer with my P2store, which had the contents of 6 cards on it, some 4GB, some 8GB. I have a G5 Mac, dual 2.5, 3GB of RAM, running 10.4.7 with FCP 5.1.1. I also have installed demo versions of Imagine Software’s P2 Log and Anders Holck’s P2 Genie to see how well they work.
I am able to take any of the P2 ‘cards’ from the P2 store and copy it directly to an external FW800 drive. It works great and is surprisingly fast, under 10 mins for a full 8gb card. Once there I can import any of the footage into FCP, no issues.
I can also import directly into FCP from any of the material on the P2Store.
I can use P2 Log to view everything on the P2 store before I do anything to it, but footage sometimes stalls out, when playing, probably due to the USB connection. Everything works fine, every clip I try opens without fail.
When I copy the individual ‘cards’ as a Disk Image via Disk Utility, four of the six work great. The copy is FAST and the verification when I open it only adds a minute or two. HOWEVER the other two cards cause the P2store to throw up an error and the transfer to stall as an ‘in out error.’ This has happened twice now with the two affected ‘cards.’ The computer had to be restarted in order to ‘see’ the P2store again.
I had a similar experience with P2 Genie, a handy utility for batch-copying the P2 material. It copied four cards fine, then stalled out with an Applescript error message: ‘Can’t make text item ‘2’ of ‘1’ into type Unicode text. (-1700)’ The supposed numbers varied each time, at each point P2Genie indicated it was copying the lastclip.txt. (Both those files appear to be fine, they’re identical to the others.) In fact the third time it stalled out with that message at the *first card* which had copied fine before. Each time the P2store had an error and both it and the computer had to be restarted to work together.
As I said, the actual clips are fine, and I have not found a clip I can’t import directly into FCP. But the direct copy method, via disk image, is supposedly the best, safest way to deal with your original material and that just ain’t working here. What is funky with my clips or the associated files that is causing disk image AND P2 Genie to choke on them? Or is it something else?
Thanks for your help…and my apologies for any imprecision in my terminology.
Alan
