Activity › Forums › Apple Final Cut Pro Legacy › problems mixing hdv and dv
  • problems mixing hdv and dv
    Posted by Stefan Kroesbacher on December 1, 2005 at 9:37 am
    Hi all,
    i’m having a problem:
    what’s the correct way to get a hdv file (cropped left an right to 4/3) in a dv sequence ???
    when i put a hdv file to a dv sequence, FCP scale this down to 50 percent with an aspect of -25.
    to get the anamorphic file back, i have to set the aspect to 0. well, so far no problems.
    but i want to crop the left and right side of my picture to get 4/3. as for my understanding, the aspect ratio tells
    the width of the picture, not the height as fcp seem to interpret it when moved to -25.
    FCP scales to 50 percent and i get a 4/3 letterbox.
    to get a full fame with sides cropped i have to scale to 70% – which can’t be corrrect for the hdv file is
    1080, and about 70% are 756 pixels in height not 576!!!!
    if i look at the hdv in the viewer at 50% it’s perfectly sharp and not blurry as in the canvas.
    If i do the same in AE i get a full 4/3 picture at 50% (actually 53% -i know..) with much better quality
    the thing is, done in FCP the hdv looks worse than the same filmed with an xm1!
    i have to scale it into a dv sequence, for i have to work with a multiclip mixed dv/HDV.
    so do i really have to go to AE to amke this work???
    thanx for any help
    regards
    stefan
    Stefan Kroesbacher replied 20 years, 10 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    December 1, 2005 at 11:34 am
    Many who are editing for output in SD use the HDV camcorder’s output settings to downconvert the HDV footage to SD (in the camcorder) and capture via FW in SD.
  • Rich Rubasch
    December 1, 2005 at 3:57 pm
    But doesn’t that yield a letterboxed clip? Try nudging up or down the scaled and cropped clip one pixel and see if that cleans it up.
    Rich Rubasch
    Tilt Media
  • Jerry Alto
    December 1, 2005 at 4:48 pm
    Stephan- Use the downconvert in the camera or HDV deck as suggested above. In the IN/OUT REC menu choose iLink HDV-DV CONV. Also in the Z-1/HVR-M10 IN/OUT REC menu is the Down Convert menu where you can choose Squeeze, Letterbox, or Edgecrop to make 16×9 into 4×3.
    Jerry
  • Stefan Kroesbacher
    December 1, 2005 at 5:21 pm
    thanx for the advice.
    unfortunately i have a fx1…
    kind regards
    stefan
