Activity › Forums › Blackmagic Design › Problems Initializing Deck Control / Changing Inputs
  • Problems Initializing Deck Control / Changing Inputs
    Posted by Bryan Hargrave on August 16, 2007 at 9:16 pm
    On my current job, out of the blue, my deck control is taking minutes to initialize. Anytime I change my input setting it takes minutes to change, as well. I just updated my Blackmagic drivers for FCP 5.1.4. I thought that might fix it, but it didn’t. I’m still chugging away with my Beta SP outputs but I’m getting close to missing deadlines. Any suggestions out there.
    Bryan
    g5 dual 1.8
    double 2gig ram
    FCP 5.1.4
    QT 7.1.6
    Black Magic Decklink Extreme Mac 6.1
    Sony DA firewire converter
    Huge 650
    Beta SP 1800
    Bryan Hargrave replied 19 years, 1 month ago 2 Members · 3 Replies
  • Bryan Hargrave
    August 17, 2007 at 1:27 am
    I answered my own question. I had my firewire DA converter on while using the Decklink Extreme to control my Beta SP via Decklinks 29.97 controller. Seems that FCP doesn’t like having both on at the same time. So when I turned off the Sony DA converter box things moved a lot faster for initializing a deck. But the question remains why is it doing this? I haven’t had a problem using both before. Decklink interferes with bringing in firewire source. This seems to be a problem that has poped up in FCP 5.1.4. Any suggestions?
    Bryan
  • Kristian Lam
    August 17, 2007 at 2:06 am
    Hi Bryan,
    Haven’t seen this one yet. Why are you converting BetaSP to firewire to bring it into Final Cut Pro? If you need DV encoded footage, just use the Blackmagic DV easy setups and Final Cut Pro will transcode on the fly into the standard DV format.
    regards
    Kristian Lam
    Blackmagic Design
  • Bryan Hargrave
    August 17, 2007 at 4:31 am
    I’m sorry after I got over the panic of delivery today. I did a full power cycle and things seem to be working better.
    By the way, I had to reset my frame offset after installing the latest drivers. I went from a 4 frame offset to a 6 frame offset. Is that normal?
    Thanks so much,
    Bryan
