Activity Forums DaVinci Resolve Problems in Renderdialog
  • Problems in Renderdialog
    Posted by Sascha Haber on October 18, 2011 at 8:04 am
    Hi there,
    I noticed a few things in the render dialog I would like to address.
    The first thing is, the render dialog now seems to remember some settings.
    That is great, but it should do that project or timeline based, not overall.
    For example, i render two sets of files here, one in source mode as EXR full res and one as ProRes half size target mode.
    I have to change destination suffix all the time because it seems to stick to the path used last, and not used last in that project.
    The next thing is I have the feeling the images are flagged LOG all the time, even when dealing with LIN/video files, not having any LUT enabled anywhere in the pipeline.
    Either Resolve should be smart enough to flag em accordingly or I should have a setting for it in the Render dialog or project settings.
    Then I wonder why I can navigate with the cursor or Wave when the render dialog is open.
    Its pretty hard to set precise in and outputs without frame stepping.
    And regarding setting those marks, should ” set output ” not by default use the output side of a clip ? Right now I have to right click a clip to get to that option.
    thanks for listening
    Sascha
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
    Sascha Haber replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
