Activity Forums Adobe Premiere Pro Problems in conforming an EDL file into SeepdGrade.
  • Problems in conforming an EDL file into SeepdGrade.
    Posted by Giacomo Turitiani on July 6, 2012 at 9:19 pm
    Hello,
    I am working on a project on Premiere Pro.
    I finished to work the video and I have decided to export it as EDL in order to work it on SpeedGrade. Then I open SpeedGrade, I select the .EDL file and here my problem comes.
    When I try to conform the video it doesn’t happen anything. What do I do wrong?
    I follow all the steps of the above tutorial (watch from 3:15 to 3:45) but as I said when I try to conform it doen’t work, basically when I push the “Load from desktop” button it doesn’t happen anything. Why?
    Can someone support me on that.
    Thanks.
    G
    Angelo Lorenzo replied 14 years, 1 month ago 2 Members · 3 Replies
  • Angelo Lorenzo
    July 6, 2012 at 11:19 pm
    In the desktop window (your file browser basically), select the root folder where all your video is, then hit “load from desktop”
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
  • Giacomo Turitiani
    July 7, 2012 at 8:57 am
    Hi Angelo.
    I tried the steps you advised but it doesn’t work yet. I don’t really know what.
    I am working with .MTS source files (AVCHD) from my Sony Camcorder, can this be the problem?
    It’s weird because when I hit the Load from Desktop button for a fraction of second pop up a box but then it dies out. I don’t know. Maybe I have problems with my SpeedGrade.
    Any advice?
    G
  • Angelo Lorenzo
    July 9, 2012 at 1:48 am
    I would check around, it may be that Speedgrade doesn’t support .MTS files. Since it’s a recent acquisition of Adobe’s, it may not be as robust when it comes to different file types.
    You may just need to use the “Send to Speedgrade” command to render out DPX frames from Premiere.
    Angelo Lorenzo
