Activity › Forums › Apple Final Cut Pro Legacy › Problems importing QT file into FCP
Barbara Santi replied 15 years, 7 months ago 4 Members · 15 Replies
Barbara Santi
January 31, 2011 at 10:45 amthanks that is useful but totally strange as its never happened before…I will stop from the deck and let you know
thanks for the advise
B -
Barbara Santi
January 31, 2011 at 10:47 amyes its firewire 800.
regardless of the capture card I dont thinkits to do with this as mentioned before I edit all the time in this way and have never had a prob
I dont know what you mean The HDV to ProRes capture trick via firewire – whats the trick?
thanks for your help
B -
Barbara Santi
January 31, 2011 at 1:38 pmthank you for all you suggestions – yes I’ve done it as Jas has suggested & it worked in stages. I did re-do the audio/video settings so who knows…
thank you
B -
Rafael Amador
January 31, 2011 at 2:15 pm[Barbara Santi] “not sure what you mean – Ive shot the 30 mins interview in HD digitising with applprores (hd) as I always do…just did exactly the same a few days ago with no prob…”
What I mean is that if you are setting IN and OUT points for capture, when you hit “escape” you just abort the capture. You end up with no clips captured.
If you are using “Capture Now”, when you hit “esc”, the footage captured is saved.
Yours sound like a tape problem.
As Shane points, set the OUT point earlier, or use “Capture Now” and “escape” before reaching the troubled area.
Tapes, don’t get “corrupted”, but a simple jump in TC may lead to those headaches.
rafael -
Barbara Santi
January 31, 2011 at 2:31 pmthanks – have sorted it out now by bringing in in chunks – yes I think the tape / timecode has something to do with…
thanks
B
