Activity › Forums › Panasonic Cameras › Problems importing P2 files into Final Cut Pro 6.
Posted by Noah Schwartz on February 4, 2009 at 12:57 amHi,
For the last two days I’ve been going crazy trying to get Final Cut Pro 6 to ingest my P2 footage. I shot the footage in 1080i 24p on my HVX200. I followed the directions from a couple of different videos on Creative Cow. I copied both the CONTENT folder as well as the .TXT file (both have locked icons on them) to a folder on my external drive. I then tried to bring that folder into Final Cut using the Log and Transfer window. Nothing happens, no error message, nothing, just back to the Log and Transfer window, no footage. I’ve been searching the forums to try to find anyone with the same problem but have had no luck. Does anyone have any suggestions or reasons why Final Cut wont except my footage?
Help… PLEASE.
Noah
Shane Ross replied 16 years ago 7 Members · 25 Replies -
Noah Kadner
February 4, 2009 at 2:50 amWhat happens when you try directly from a P2 card- say via the camera.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
https://www.callboxlive.com -
Noah Schwartz
February 4, 2009 at 6:47 amI also tried directly from the camera and got the same thing…. nothing
Shane Ross
February 4, 2009 at 8:09 amDo you have FX Factory installed?
Shane
Read my blog, Little Frog in High Def -
Shane Ross
February 4, 2009 at 7:04 pmSo you have FX Factory installed? Yes, that can be the issue. Unless you have the latest version, it interferes with P2 import.
https://lfhd.blogspot.com/2007/11/fcp-602-busted-p2-import-one-fix.html
Shane
Simon Morice
February 19, 2009 at 9:10 amI too am having similar problems with P2 data. I tried the FX Factory install but that doesn’t seem to have sorted things. It also won’t allow you to uninstall – I am guessing until you’ve started the trrial or bought a license.
I spoke to Panasonic at the Broadcast Expo in London yesterday as well as to some Apple people.
I tried drag and drop from Finder to the top left FC window and got a dialogue box ‘Please choose a translation document file’ which when you hit OK opens a Finder box. But which file? I then had to force FCP to close as it got into a bit of a loop looking for the translation file.
I also can’t find Panasonic P2 under the Import menu. My FCP is up to date as is Quicktime.
Tomorrow I am at a training seminar given by Larry Jordan. Guess what I’ll be asking him???
Shane Ross
February 19, 2009 at 9:22 am[Simon Morice] “I tried drag and drop from Finder to the top left FC window and got a dialogue box ‘Please choose a translation document file'”
Because you cannot import the MXF files directly into FCP without something like Raylight or MXF4QT…and then you need to use proper steps.
[Simon Morice] “I also can’t find Panasonic P2 under the Import menu.”
That option has changed names. It is now FILE>LOG AND TRANSFER. Because this interface now imports more than P2….AVCHD, AVCIntra, RED.
Tell Larry I said hi!
Shane
Simon Morice
February 19, 2009 at 11:28 pmThanks Shane and I’ll pass on your greeting.
Still dumbfounded.
At the show today I was told by somebody from an Apple Solutions house that drag and drop works because FCP can work out what is needed – all part of the seven billion and eleventy three different ways Apple give us to do things. Although in this case it seems not to do anything more helpful than put FCP into a loop from which there is no graceful exit.
The message about the translation document (XML stuff?) apparently means that the codec was not properly installed. So I reninstalled it.
In fact I have reinstalled all the various P2 driver doodads I could find and have also removed the Sony SxS card driver which apparently cannot coexist (https://forums.creativecow.net/readpost/193/874346) with P2 (funny that!).
After all of this Log and Transfer still fails to work.
From all the vids I have seen import should be a very simple process yet something is preventing it.
Log and Transfer continues to work fine with XDCAM yet nothing is visible for P2 data.
I thought it might be good to reinstall Quicktime (not from update but from a full download so I can roll it back if needs be) and to top off my tale of woe, from my current location in London the Apple site keeps timing out. London isn’t the same since Boris became mayor.
I am soooooo relaxed about this!
Is there a set of instructions which describe the precise requirements for what should be there and what must be removed?
There must be some conflict somewhere to give me this degree of clusterlovliness.
Regards
S
Shane Ross
February 20, 2009 at 12:13 am[Simon Morice] “I was told by somebody from an Apple Solutions house that drag and drop works because FCP can work out what is needed -“
Did you tell them this was P2 footage and not QUICKTIME? Anyway, even if it WAS Quicktime, that doesn’t mean it will work. That is someone who CLEARLY doesn’t know what they are talking about.
Try to remove then reinstall FCP…and upgrade to latest version.
https://www.digitalrebellion.com/fcs_remover.htm
Shane
Simon Morice
February 20, 2009 at 12:39 amThis is P2 footage copied straight from the card to an external HD not Quuicktime. There is a Contents folder with all the data in as well as a lastclip.txt file in the card folder. It plays fine in the P2 equivalent of a clip browser.
I’m now quite depressed at the thought of an entire reinstall. Everything else in Final Cut is at the latest version and is working perfectly. P2 is the only thing that won’t work.
Judging by the posts to this site there do seem to be a number of people having issues with P2.
