Activity › Forums › Apple Final Cut Pro Legacy › problems importing mxf file in FCP 6.0.5
Posted by Rainer Wirth on April 28, 2009 at 11:55 amI can’t import a mxf file in FCP. The file is probably made with Premiere.
Any ideas?thanks Rainer
Bjoern Adamski replied 17 years, 4 months ago 6 Members · 8 Replies -
Rafael Amador
April 28, 2009 at 12:21 pmHiRrainer,
If you copy this: MXF IMPORT
Then you paste it in the Search Window (up there) and click “Search” you will find 250 post related with this topic.
Im sure that the answer is there and you will find it.
If you don’t find it post me back 🙂
Rfael -
Dennis Radeke
April 28, 2009 at 1:03 pmIn Premiere Pro, it natively supports .mxf files. In FCP, you must open up the Log and Transfer window and convert it to ProRes. Once it’s converted, you should have no problems using it in FCP.
Rainer Wirth
April 28, 2009 at 1:12 pmthe icon of the mxf files is not active, so I can’t log them. If I can’t log them how can I convert them into pro res ?
Rainer
Jeremy Garchow
April 28, 2009 at 2:15 pmIf you need to natively edit MXF files in FCP, try MXF4mac. WHere did the MXF files orginate from?
Jeremy
Shane Ross
April 28, 2009 at 2:18 pmPremiere doesn’t make MXF files, Avid does. So do P2 cameras, but they need to be in a very spedific file structure in order for FCP to work with them. In order to import this file you need to know EXACTLY where it came from…no guessing here.
Shane
Read my blog, Little Frog in High Def -
Dennis Radeke
May 1, 2009 at 12:20 amYou’re right here of course – you need to know where the MXF came from. MXF is an open standard that is a container format that contains video, audio, metadata, etc.
Premiere Pro CAN create MXF by the way. You can take any media and export it as Panasonic’s P2 – the format most commonly referred to as MXF.
Jeremy Garchow
May 1, 2009 at 1:44 am[Dennis Radeke] “the format most commonly referred to as MXF.”
Avid’s capture and wrap media as MXF as well.
Bjoern Adamski
May 6, 2009 at 12:59 pmThere is an issue currently with P2 MXF files created with Premiere, please see here:
https://mxf4mac.com/compatibility
Product Manager
MXF4mac
https://mxf4mac.com
