Problems importing mp4 file into premiere
I have a previously exported game clip that I’ve made, its only about 20 seconds long. When I imported it back into premiere at a later date in order to implement it into a longer video, it freezes halfway through, then unfreezes after 5 seconds or so. The audio continues to play. No matter how many times I import it, the freezing is always in the same time frame.
I’ve had this problem before but with raw recorded footage due to non variable framerates. But its odd that something that previously worked fine on premiere no longer does. Also, it plays fine in all other programs, such as vlc player.
Help appreciated.
