Activity Forums Apple Final Cut Pro Legacy Problems getting D.A.T audion into my G5, please help!!!
  • Problems getting D.A.T audion into my G5, please help!!!
    Posted by Dave Sullivan on October 14, 2005 at 12:49 am
    Hello All,
    I’ve just tried to copy some audio I recorded on Monday onto my G5, and I’m having problems!!!!
    I realised after trying to get the audio from my D.A.T recorder into FCP 4.5 that it’s a no go. At the moment at can only Record 1 mono track in FCP, and thats by using the ‘Voice over tool’….any ideas?
    Many thanks in advance
    Dave
    Dave Sullivan replied 20 years, 11 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    October 14, 2005 at 1:34 am
    There are several ways to do this.
    The simplest is to record the DAT to your camcorder and a DV tape, then capture the DV.
    It will then have timecode and that can come in very handy.
    There are other methods, depending on the equipment you own and your experience-level.
  • Gunleik Groven
    October 14, 2005 at 8:17 am
    If you have a DAT player and a G5 with spdif optical I guess you’re in luck.
    Just connect the two (You might need a 50$ cable to lightpipe converter or a 10$ lightpipe cable).
    In “Audio Midi setup” you configure the computer to accept sound through the lightpipe and external sync.
    Do not try to make the connectio bi-directional! The G5 isn’t very good at that… -;(
    This way you’ll get a clone of what’s on the tape to disk. Or so they say at least…
    If you have QT 7 pro, I think you should be able to record the sound directly into QT. If you’re on FCP 4.x you can record into Peak.
    Hope this helps
    Gunleik
  • Dave Sullivan
    October 14, 2005 at 8:39 am
    Many many thanks indeed……I’ll give it a try!!!!!
